goatiegoat1
I know the leaks have been discussed over and over. You would think Ram should have solved, this problem but I digress.
I am not a car guy and could use some help. I have a leak in the rear of my truck (2015 ram 1500 big horn quad cab).I have head liner damage and have seen it dripping after a heavy rain. I have also found pooled water in the storage area under the rear seats. I have replaced the third brake and silicone around it and along the top of the rear window from corner to corner. Still leaking. I would like to be able to check under molding strips that run from back to front on either side of truck, but unsure how to do it. Would love some insight into my problem.
Thank you
John
Thank you
John
