1SloRam
As long as it works for ya, lol.The q20s sit just off of 12 and 6 and are not adjustable. Beam pattern is a little jacked, lol, but for the price I cant complain too much though
If the bulbs have plastic bases, the part that has the cut outs that lock into the housing, you can use a pair of nippers and clip the plastic back to get a proper fit. I had to do that with my daughters Civic. No way I was spending a fortune on a 13 year old car with 212k miles college kids car. Just gotta go slow and take off a tiny bit at a time.The q20s sit just off of 12 and 6 and are not adjustable. Beam pattern is a little jacked, lol, but for the price I cant complain too much though
If you have projector headlights just loosen the 3 screws, turn to where its 9/3 and tighten back down.The q20s sit just off of 12 and 6 and are not adjustable. Beam pattern is a little jacked, lol, but for the price I cant complain too much though
I know we've been focused on projectors a lot here, but a couple of quick questions....
Has it been found "clocking" is still needed in the "quad" headlights?
If you replace just the 2 low beam bulbs with LED, and leave the high and fog at halogen, will that cause computer codes? Meaning is it better to replace them all to LED while you are in there.
And I'm really nervous about just installing bulbs without running into flickering issues (with every bulb), is it best to just install the additional harnesses anyway and be done with it??
I'll take anybody's opinion or experiences I can get in regards to the purchased bulbs, harness usage, and things to do, or avoid, on a quad LED headlight set-up.
Are you happy with the light output with these? I tried the stock halogens, Sylvania Silverstar Ultras, and Cougar Motor Evolution+ LEDs and still ended up taking them out. It's dissapointing because I did like the looks of them.I am using alpharex pro G2 with canbus ready LED bulbs. Only other led bulbs is the reverse lights. The taillights are factory housings.
MB7640, were these the ones you used? Auxbeam 4400LMI use auxbeam in my 2021 classic. Installed them in jan no issues.
