SunnyFL
I bought some LED High beam bulbs. Supernova V.4 X - 9005
It is really tight in there. The back of the bulb (the fan and heat sink) is really close to the dust cover. And there is not really room for the adaptor. The installer drilled a hole to run the wire out and to give the bulb some breathing room. Not sure that is such a good idea. Not sure what my options are.
I could use heavy duty duct tape to close the hole, but not sure if that is a fix.
I'd appreciate any ideas?
