LED interior lighting
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
Well I should've spent the money right and bought led's from superbrightled but I didn't. I got an interior package from iJDMTOY.com and the dome light led isn't even big enough to fit in the contacts. The kit says 09-13 ram. Anyone else had any problems like this from off brand places?
MaizeNBlue
Nope, I went with superbright and diode dynamic off the bat ...even then the cargo light was a challenge to replace ...I have a '16 .... I ended up taking a pic of the oem bulb with a tape measure, sent it to superbright .... finally got the right one.
1SilverBullet2
1SilverBullet2
North Dakota
I think I'm just gunna contact superbrightleds and get the right lights the first time and send these other ones back.
Sent from the howitzer
1SilverBullet2
1SilverBullet2
North Dakota
Well the truck is in the body shop now so I'll have to wait a couple days so I can check out and see if the rest of the lights fit and work or not. Kinda wondering even tho the LED map light was too small to fit in the contacts it never came on, both metal ends were touching the contact clips? Also any tips on removing the over head console to get at those lights?
clifford15
RI
CTD
Enlight interior LEDs work great and they have great customer service which is a huge plus. I had a rear dome led that failed and they sent a new one out immediately.
https://www.enlightauto.com/
1SilverBullet2
1SilverBullet2
North Dakota
Thanks if things don't get fixed with this company I'm dealing with now I'll get some from Enlight, those look good and fairly priced.
1SilverBullet2
1SilverBullet2
North Dakota
Anybody on removing the map lights in the overhead console? Does the console just pop off?
If you have conventional bulbs in the map lights, you just remove the clear plastic lens. Carefully pry down as there is a little tab.
From what I've read on removing the entire overhead console, you start by prying the front down, there is probably a YouTube video how to pull it down.
1SilverBullet2
1SilverBullet2
North Dakota
Just a little update, I changed my interior lights. The dome light in the back is fixed I guess lol. I just bent the contact prongs tighter and put the LED bulb in, it's tight and doesn't move easily. We'll see down the road if it loosens up at all.
