LED light Bars,
S
scHemi
2009 RAM SLT Crew
Thanks. And what's the legality of having that bar? Off road only? Or does he use it when he is all alone on the road
yodge
Huntington Beach CA
2013 ram 1500 hemi
California law
It's a offroad light only. Any lights higher than your factory headlights require a cover. Not every does have covers. More people do not have covers than do. If you turn it on you will blind any oncoming drivers and potentially cause an accident
tyler
Maryland
Thanks for the tips guys! :favorites13: Just got mine done last weekend.
after looking at the rigid and a couple other brands, I settled on trying out a "cheap" lightbar from amazon, Im very happy with my purchase.
Heres a link: Amazon.com: 120w Light Bar Led Cree 20" Spot Combo Work Off Road Fog Driving 4x4 Bumper Rock: Automotive
Heres some pics.
Dark
stock low beams and fogs
stock high beams
Stock high beams with lightbar
lightbar only
Fitment. Still waiting on my tow hooks to finish trimming the plastic insert... also had to flip the licence plate bracket as stated earlier, it works but the plate faces down instead of straight ahead, Ill eventually modify that a lill more..
Definitely not street legal. at all. lol. :roflsquared:
how did you wire it up I want to use the same one! looks amazing also wondering if you just drilled throught the support brackets to mount.
Skies388
Cummins 6.7
Anyone put one of these in a non sport bumper had issues with it blocking transmission cooler I believe on the 3500s?
92GreenYJ
Spring Valley, CA
Got my curved 20" installed Saturday morning on my sport. This thing is bright as hell! As mentioned above, to mount I just drilled two holes in the bumper supports and bolted it in.
srtpowa
Sacramento, ca
hemi 5.7 w/ 6 speed
how did you wire it up I want to use the same one! looks amazing also wondering if you just drilled through the support brackets to mount.
Yessir just marked it, drilled it, then mounted it up!
I ended up buying a wiring kit as well for it. At $16 Ifigured it was cheaper than spending time making one.
ill go grab you the link :naughty:
http://amzn.com/B00D1CQVIY
tyler
Maryland
tyler
Maryland
Did that wiring harness just plug right into the light? I've never wired a light bar before?
92GreenYJ
Spring Valley, CA
My light bar came with a full wiring harness with a switch and relay. I did change the switch out for a better one. But all it needed was a ground wire and a power wire hooked up. I did modify the harness a bit as it was way longer then I needed so I cut it down a fair bit. The light bar on my Jeep didn't come with a harness but it was only two wires for the bar. A power and a ground. I wired it up thru a standard relay and a switch. Easy enough.
srtpowa
Sacramento, ca
hemi 5.7 w/ 6 speed
Thanks a lot for that... Was your lightbar curved or straight?
No problem! good luck with your install. Mine is just straight, no curves.
11BPSMIKE the kit i posted came with a switch. tigger goes to the battery :superhack:
stevenmicheal
