Josh Morlock
I put LED bulbs in my map lights and dome light on my 05 ram 1500 a couple years ago. Always had an issue where the lights would be always on but super dim, they do shut off when the key is off. When you try to turn the map lights on it just goes from a super dim light to no light at all. They work fine when you open the doors or manually turn on the dome lights with the scroll wheel on the dash but the map lights themselves do not work right. Just wondering if anyone would know a fix to this issue?
