LED Overhead console
mjscharlotte
Charlotte, North Carolina
5.7 Hemi V8
Hey guys,
I've looked and can't find a link to the correct bulbs. I'm wanting to replace the factory LED bulbs with aftermarket LED bulbs in the map lights located in the overhead console. I have a 2017 1500 Limited and bought some Auxito bulbs that said that they were the same length as the factory halogens - they weren't. The plastic lens has a little bubble thingy on the inside of it and the bulb hits it when I try to put it back in place. Does anyone know of a link to bulbs that you know work? Thanks
misfit77
The two bulbs above are 194.
The rear is festoon, sorry i dont have dimnsions
Sent from my moto g power using Tapatalk
misfit77
I bought multiple brands and all fit. I am thinking you got "special" ones.
These fit, but could use another .20 or so.52f23284488915521574f23e705e75c7.jpg
mjscharlotte
mjscharlotte
5.7 Hemi V8
misfit77
Be mindfull that theres a little tab that has to sit in the switch or ut wont go in.
Does your lights look like this?
I have plenty of room.0735f7dd33ddcc38179b8f68c3f931ca.jpgab1fa76588a7f617079505cd5124c91f.jpg5907f614c8bd8d11e47446d374648b54.jpg
Jessica Smith
Houston
Don't know if they are the best, but I'm happy with them and have been using these:
https://www.amazon.com/gp/product/B071ZXTDBD
and
https://www.amazon.com/gp/product/B07QB6QFN4/
They do dim off though instead of digital off or flicker off, which was something I was worried about.
Kind of a waste to have leftovers though if you're not doing several vehicles at once. I had seen others post actual Ram 1500 kits so you have just the right amount you need for everything.
george55378
Tower,MN
Hey guys,
Try looking into Aliexpress. A **** ton of selection there.
