LED reverse light pod wiring from the trailer harness
Ladder20Roof
So i tied the pods into the trailer harness red to the white with red stripe, and black to the white with black stripe, thinking that they would turn on with the reverse lights... nada... any ideas?
akennedyusmc
I would just got the extra 4-5’ and tie it into either one of your reverse wires on your tail lights.
Administrator
I'm not sure of the wire color but it's the wire going to the center terminal in the 7 pin trailer plug for the reverse lights should go-to the positive wire for the pods.
You don't want to wire them to the reverse taillight circuits, several on this forum have tried and it causes bulb out errors and the lights not working. Not to mention this is on a '15 which are usually more particular about lighting changes.
Did you check the F28 FFM 20 amp Trailer Back up lights fuse?
One of the easy ways to hook lights up to the trailer harness is use the the Curt 56584 That gives you a five flat which includes the reverse light wire. https://www.amazon.com/dp/B007EA6WQU/
L
Ladder20Roof
Thanks, I'm going to go for the lights themselves next, i didn't get any bulbs out warnings with the trailer harness
bm02tj
B C Canada
Led is polarity sensitive check your power and reverse wires
I wired my in to the trailer plug wiring
will have to find info it you need
L
Ladder20Roof
I used the ground, white with the black stripe, in the harness and the white wire with the red stripe threw the truck into reverse and... nothing
JB1
Houston, Texas
I’m not sure of colors but reverse is in the center and you can get ground at the connector or just on the frame somewhere
akennedyusmc
That’s interesting. I did this to my ‘17 and never had a problem. That crazy that this didn’t work for some guys.
L
Ladder20Roof
You went from the taillights? Or the trailer harness?
L
Ladder20Roof
Do i need to thread the 12v hot into the reverse light somehow or should there be electric through the reverse wire?
Administrator
You would wire the LED pods to the reverse wire for the trailer plug and the to ground(body or the ground wire in the plug). That reverse wire provides the power to light the pod when in reverse.
The +12V connect in the trailer plug provides constant power and is used to provide power to the trailer, usually for charging the break away battery.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
yes sir, sure makes it easier
L
Ladder20Roof
Ah my harness must be screwed up then, its wired correctly just not working, ididn't use a relay tho...thanks for the help
Administrator
Did you check the F28 Trailer Tow B/U fuse? Each pin has its own fuse and that type of fuse(FMM-20) is hard see if it's blown, you'll want to use a meter.
akennedyusmc
Sorry for the late response. I wired into the drivers side tail light
