LilredHemi
I have these taillights on my 05 Ram 1500 Laramie. When I initially got them and plugged them in they didn't work. I found that the ground wires in the connectors had no pins to mate with the ground connection in the truck connector! I found a set of extension cables on Amazon and was able to rewire them. All worked then except for hyper-flashing of the turn signals. I installed load resistors and the right lamp flashed normally but the left continued to hyper-flash. I found that the left load resistor had melted or broken a wire off, replaced it and all was fine except applying the brakes causes the selected turn signal to hyper-flash. Do I have to put a second set of resistors on the brake lamps as well?
