Led Taillights technical question
Kalill Nieto
Fort Lauderdale
Hello guys.
The 2019 and up Led taillights has a "sense" wire connection.
I know that the 4th gen OEM Leds taillights has a sense wire too that read a ground when brake or turn signal is activated.
I need to know if the 5th gen Leds taillights are the same.
Thanks in advance.
superjoe83
Oregon City, OR
Yes, it toggles to ground just like the '13-'18 tails do, but only for the amber turn signal feed, it does not toggle for the brake light feed. I tested my '19 tails before I swapped them to see if they would work with the fault sense wire.
Kalill Nieto
Kalill Nieto
Fort Lauderdale
Do you think that if I connect that sense wire to a 5th Led taillights will help to avoid errors codes in the 4th with factory Leds? [emoji848]
