LED Upgrade
BlownGP
Houston/Baton Rouge
The cargo lights are 921.
The reverse lights are either 7440 or 921 I'm guessing it depends on whether or. Or you've got the LED taillights.
I buy mine from VLEDS.com.
Just fyi...... 921s are the same as 194s in the LED world..
dmullen
HEMI 5.7
So are the LEDS listed in the very first post of this thread still good for a 2014 Express (Quad/HEMI)?
brasso
2012 ram 1500 4x4
What are the side marker led lights??
Also anyone know what the reverse, tail, and cargo lights are?
I have a 2012 ram lone star
BlownGP
Houston/Baton Rouge
mmwaggie
Doesn't help me any, only lets me select Ford, and doesn't answer my original question about the SuperBrightLEDS the original poster listed.
My Buddy at work just got an express and I'll check his out for you and let you know what I find.
I just ordered mine. I'm not going to replace the upper glove box/license plate/or the visor lights. I do have the foot well lights so I got LEDs for those. Hopefully all will look good. Thanks OP for the write up and for making it extremely easy to find the right LEDs on superbrightleds. :happy107:
mmwaggie
Pretty sure 921 is the right size. I think I remember reading that the bulb mounts from the bottom so the light is vertical. So you would need a side-emitting LED. I could be blowing smoke out my **** though about that last part.
Midnight_Express
The reverse lights and cargo lights are next when there is a good 921 bulb that is side firing for the reverse lights.
I got these bulbs the second day I had my truck , just a few weeks ago and they are awesome .
JDM ASTAR 800 Lumens Super Bright AX-2835 Chipsets 7440 7441 7443 7444 992 LED Bulbs ,Xenon White
atanasiog
New Jersey
5.7L V8 HEMI MDS V.V.T.
Thank you!!
THANK YOU!!! YOU SAVED ME!! I've been googling for hours trying to find the correct size bulb for the map lights.!!!!
SixPoints_Kev
Las Vegas, NV
2019 Laramie 2500 Mega Cab
6.7 CTD
Anyone know how to fix the error codes for the plate lights and reverse lights? I've tried switching to led's and as soon as I start the engine it throws codes for both. I got so tired of seeing it that I put the stock ones back in but it still bugs me...
darthdzl
Phoenix, AZ
2017 Tradesman RCSB
V6
Which ones did you get, and from where?
SixPoints_Kev
Las Vegas, NV
6.7 CTD
Darthdzl, I ordered them from DDM, actually picked them up cause I'm local. It was the "7440 / 7443 LED, 23 x 5630 SMD" for the reverse and "194 LED Bulb, 6 x 5630 SMD" for the license plate. The bulbs worked great, but I couldn't get rid of the error codes.
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
I have a '15 Express and i've used iJDMTOY led's from Amazon.com for back up, lic plate, 3rd brake, and interior led's without any codes or issues!
darthdzl
Phoenix, AZ
2017 Tradesman RCSB
V6
I got mine from SuperbrightLEDs.com and they're all CAN-BUS versions. Are the ones that you got CAN-BUS? I think they have to be before or the computer will ***** about it.
SixPoints_Kev
Las Vegas, NV
6.7 CTD
That's probably the difference. Didn't know there was such a thing as a canbus led. Thanks!
SixPoints_Kev
Las Vegas, NV
6.7 CTD
Thanks CMil.
Darth, can you tell me the exact bulb you ordered from SuperBright for your reverse? I found the 194 can bus bulbs without a problem but, every 7440 bulb they have specifically says "No" for can bus...
CMil527
Old Bridge, NJ
