LED Upgrade
darthdzl
Phoenix, AZ
2017 Tradesman RCSB
V6
Thanks CMil.
Darth, can you tell me the exact bulb you ordered from SuperBright for your reverse? I found the 194 can bus bulbs without a problem but, every 7440 bulb they have specifically says "No" for can bus...
Okay, so I'm guessing you have factory LED taillights? Because you use 7440s for those, and 921s for trucks without them.
Retro-solutions actually has 7440s that work well, and they're probably brighter than the SuperBrightLEDs ones. Here are those:
7440 7443 T20 6W CREE LED Reverse Side Emitter Wedge Bulbs - Retro-Solutions Store
And you're right, I can't find a CAN-BUS one from SuperBrightLEDs. Mine uses 921s, and I failed to take into account yours might be different. Sorry about that. This one is the one I'd pick if I was willing to risk having to send it back:
https://www.superbrightleds.com/mor...y-28-high-power-led/1647/#/tab/Specifications
But to tell you the truth, enough people have had good luck with the Retro-solutions ones, I'd go with those. Comparing the equivalent 921s, the Retro-solutions ones ended up being way brighter, because the bulbs are canted at an angle in the tallights, and the RS ones account for that, whereas the SBLEDs ones are all-around-emitters. Not sure if the situation is the same in yours or not, since you use the 7440s.
EDIT: If you don't have factory LED tails, then you need 921s instead of 7440s. Just say so and I'll throw you those links as well.
SixPoints_Kev
Las Vegas, NV
2019 Laramie 2500 Mega Cab
6.7 CTD
My bad, I probably should have stated that from the beginning. I do have the factory led tails, and the bulbs are at a 90 degree angle in the housings (if that makes sense).
Thanks for the Retro Solutions link, I'll just order those. That should take care of the error codes. The bulbs I found on SuperBright were VERY similar to the ones I previously purchased from DDM, so I was a little weary about ordering those and having to return them.
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
Yes sir my Express Black Edition has led tails!
Jdoidge92
Canada
Where did you purchases these LEDs? online or at your local shop?
I bought a bulk buy of LEDs but some of them are burning out and not all matching colors,
just cheap quality.
Malibuz0r
Anyone have a link for the correct cargo lights on superbrightleds.com?
thegreat22
2015 Ram Express 1500 CC 4x4 - Black Edition
will these part numbers work for a 2015
CiggyByrns
US Navy Retired IYAOYAS
Houston, TX
6.7L Cummins
I'm looking for an LED upgrade for all interior lights but I want them in red. I currently have some but they were cheap and aren't as bright as I would like. Anyone know of a quality site or company that would have some that are brighter?
LB3711
LB3711
Trumbull, CT
3.6L V6
use the same site where I got mine from. All mine are still going strong. None have died yet
USMC_Ram909
Ok so now after reading all the pages and different threads I am officially lost!!I am looking to replace my dome light, reverse lights, cargo lights, and license plate lights with LED's. I have a '12 CC express so in the cab I just have the single overhead dome light not the map lights upfront or light in the back seats and my tail lights are regular not factory LED's. Anyone with the same truck do the upgrade and have the bulb types? I am probably going to go with superbrightled or vled as those are the ones i've seen the most reviews about. Thanks in advance for your help guys!
LB3711
LB3711
Trumbull, CT
3.6L V6
its easy just follow my original post. Still to this day everything is still working 100%
USMC_Ram909
For sure. What reverse did you end up using?
USMC_Ram909
Are these 921's also good to use in the reverse lights? So far I have in the cart 2 of those 921's for the cargo light, 2 of the 921's for the reverse, the 4410 for the center dome light and 2 194's for the license plate lights. I just want to make sure I order the right bulbs and amount the first time. Thanks for the help!
https://www.superbrightleds.com/mor...cluster-miniature-wedge-retrofit-car/203/901/
https://www.superbrightleds.com/mor...d-led-miniature-wedge-retrofit-car/3551/7577/
https://www.superbrightleds.com/moreinfo/festoon/578-led-bulb-9-led-festoon-44mm-car/237/1123/
Treburkulosis
Glorified Car Washer
Haslet, TX
I am working on a complete LED conversion thread. I will finish it up tomorrow. I changed every bulb that could be changed to LED.
Mints
Issa Hemi
Has anyone used the CAN-bus LEDs in place of the license plate, reverse lights, and cargo/3rd brake light from Super Bright LED? Getting ready to pull the trigger for my '11 1500 and just want to make sure there are no issues.
LB3711
LB3711
Trumbull, CT
3.6L V6
so have i. all interior lights and exterior lights are LED. Headlights are HID and high beam are still halogen. I need to find a good reverse LED because i have the 2013 OEM leds tails and the reverse bulb is different than my 2011 tails.
pkillian
