LED Upgrade
cccp1989
Cleveland, Ohio
2011 Dodge ram 1500 5.7L V8 Hemi Sport
Hemi 5.7L V8
This is what I found out. This how mine our. When the truck is off and the doors are closed and i press the led light it does not turn on. But when the truck is started they all work even when pressed.
Sent from my HTC_Amaze_4G using Tapatalk 2
BigDogg795
Ronkonkoma, NY
Lol, mine flashes! :anitoof:
LB3711
LB3711
Trumbull, CT
3.6L V6
Mine all work like normal. Just as the oem bulbs do.
Sent from my tapatalk equipped AT&T iPhone 5
Sweetee
Wisconsin
2017 Ram Laramie CC 4x4
3.6 Pentastar
Greetings,
Sorry I don't have pix, but here is what I did. I wanted a bit more light in the cab of my 2012 Express RCSB. Not having lights in the footwells has been a disappointment and I still haven't figured out a "clean" way to add footwell lights. I ordered 2 of the following on Amazon (Amazon.com: NEEWER® T10 36 SMD LED Light Festoon Dome Bulb Lamp White 12V: Home Improvement). I spliced them together and replaced my single dome light bulb with them. I now have 72 LEDs lighting up my cab. The wife is worried that landing planes will mistake me for a moving signal beacon! When she goes shopping at night, I can now read in comfort while I dutifully wait in the truck!:winner_first_h4h:
LB3711
LB3711
Trumbull, CT
3.6L V6
you can do that but I went with the factory look. I didn't feel like retrofitting a LED panel in there
usmfan789
jacksonville, NC
Man just got my bulbs in the mail not gonna lie I stared at the bulb names for twenty mins before it suddenly hit me how you listed the part but hoping to have them done up by sunday
LB3711
LB3711
Trumbull, CT
3.6L V6
do it. its well worth it
Sent from my Transformer TF101 using Tapatalk 2
usmfan789
jacksonville, NC
I'll post pics when I get to it.... As soon as I got my bilsteins in The mod bug hit hard my wife is getting furious with me lol
cccp1989
Cleveland, Ohio
Hemi 5.7L V8
I got 20 led bulb for map light and 16 led bulb for rear.
Bob crew cab
Georgia
Got my leds installed. They flash when the truck is not running. Work normal when the truck is running. If I leave one of the factory bulbs in the map light every thing works fine. What do I need to do to fix this problem? Thanks Bob
usmfan789
jacksonville, NC
Well got the LEDs installed, i shorted one of the visor bulbs cause i forgot to disconnect the negative on the battery like a idiot , once it gets dark I'll take some pics, LB3711 how'd you get the upper glovebox bulb swapped over? I can't get my fingers around the bulb
BigDogg795
Ronkonkoma, NY
Coincidentally, mine does the same. If I need the light with the truck off, I just rotate the dimmer switch full right.
:ryu-cvs-hadoken-a:
Stangshcky12
Oshkosh, WI
5.9 Cummins
My dads flash too but will stop if you open the glove box lol
I pulled the upper and lower glove box out to change that bulb
It's one 9/32 bolt (I think) to remove and you have all the room you could want to get he bulb put and back in
TexasCornBread
Old River,Texas
5.9 magnum
Beautiful work . Also good right up on bulb numbers
TexasCornBread - If you can't Dodge it RAM it !
stevenmicheal
