Level kit for 2wd
TeamSDL09
Anyone have any pics of there 2wd ram leveled? Not sure how big of a level i need to go or can go. I want to throw 35s underneath it to fill the wheel gap. Im adding a 1" wheel spacer hub centric.
yodge
Huntington Beach CA
2013 ram 1500 hemi
Probably won't fit here's mine with just a level ImageUploadedByTapatalk1416713415.603874.jpg
A long long time ago haha
EDIT: the top pic is leveled with 285 70 17
(33's)
2014Knight
5.7L HEMI
Heres mine with 1.5in from Performance Accesories, the website says you can fit 34"s im going to run 33"s
OutlawTrucker
Meansville GA
Cummins 6.7
I have a 2" billet level kit with stock 2500 shocks(2" longer) for sale. Removing because I'm dropping the truck
TRIGGER_Hemi
i noticed the 2wd 14s don't have much of an option. as of now if i do a lift its gonna be a CST spindle
RyanJM
Houston
2014 Express RC Black Edition
I wanted 35's on my 14 2wd with no worries about rubbing. I used the maxtrac spindles and 3" rear coil kit. They also have a setup with rear spacers but I wanted some take for when I tow. Cost me $850.
RyanJM
Houston
I will measure the ground to center bottom of the flare 43f and 43 1/2r give or take 1/16" it was getting dark. Without the flare it would measure a little taller. Truck looks like it has more rake then it actually does.
RyanJM
Houston
Thanks for the info; truck looks awesome man. I'm still trying to figure out my setup. I took another measurement tonight - top of wheel to bottom of wheel well - I'm at 5-5.5"...kinda worried about having a 10" gap if I install the 4.5" spindles.
10" gap where? The flares only sit a 1/8 to 1/4" lower than the bottom of the stock wheel. What are you running now? What do you want to run? Tire wise and height? Tell me your setup. I have seen the 7" Maxtrac on a truck with 35x12.5's different brand wheel/tire than mine. Looked good. I want to up it to the 7" of i keep mine and swap on 37x12.5's.
RamminJammin
Working on uploading a picture iv got a fat bob garage 2" level 60$ on my 14 2wd with 2500 shocks for another 60$ it will more than likely clear 35's especially if you are adding a wheel space. Offset is the name of the game there's a guy on here with a 3" level running 37"s with a crazy offset and no rub. I also have mevotech uca's on the way and 1/4" spaces on all four corners. I'm going to run 35's once th stock tires are done. Weather they rub or not I've got the skills to trim plastic and order different spacers. I've looked into a 1 1/2 body lift as well but it really doesn't give you a ton of extra room. Hope this helps will try and get the pic up today.
RyanJM
Houston
You could just use the spindle with that size tire and add the spacer in later if you want to go higher. To me the spindle with a 34 to 35 fits perfect. Plus it drives the same as when it was stock. It is a lot better than my 09 that I had with a 2" spacer and longer shocks on.
TheM4rxxx
