level kit
TheMaddog
DFW
i want to make the back match the front, I'm not sure which way to go on this, i'm not looking forward to spending $300. this is my money, not my parents, and right now, I'm jobless.
HemiBabe
DFW
I don't really know what to tell ya... you gotta pay to play... You can make your own flip kit from Tractor Supply using trailer saddles blocks and weld them on and flip the leafs, but that is going to give you a 6" drop and then you have to pay to get a c-notch done which is about another $400 prolly.
I would just save up your money and buy a kit or find one used. Or you can just use the shackles from auto zone, but it won't make the back match the front at all.. it will look like mine did with the 2" McGaughy shackles :
VS. the 2/4.5 drop in my sig
quietpeen
2021 TRX
Hellcat
i would think he could just get away with drop shackles
TheMaddog
TheMaddog
DFW
Does it go on just like how the old one goes on?
quietpeen
2021 TRX
Hellcat
pretty much. Its just a shorter shackle
TheMaddog
TheMaddog
DFW
The one I saw was bigger, much bigger.
quietpeen
2021 TRX
Hellcat
it wasn't a drop shackle for a 3rd gen then
TheMaddog
TheMaddog
DFW
It's just a shackle. Didn't really have a specific fit for it. But maybe if I put that and a flip kit together...
HemiBabe
DFW
When the leaf spring is in the stock position, the shorter the shackle, the more you drop.
When it is flipped, the longer the shackle, the lower you go.
This is what the correct 2" shackles look like for our trucks: [The OEM shackles are 2" longer]
EJM05
Somers, CT
440 Big Block
Dude you must have like a million threads about this same topic. You gotta spend the money to get the mod.
TheMaddog
TheMaddog
DFW
Erik, I'm not sure if you know this, but I'm not made of money. I have to save up, and that takes a long time. I'm just trying to find the best/cheapest way to do this and not make it look like total ****.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I ran drop shackles on my 08 for a bit. squeaky little ********.
I don't miss those days .
TheMaddog
TheMaddog
DFW
I read somewhere that if you do like 20 lbs of pressure, you'll get the full drop and no squeak.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
no.
shaunnz
