ZAID AKREM
I checked and both same ratio, also I replaced the old oil when I installed the diff in!First thing I would do is verify the front and rear diffs are the same gear ratio. Not sure if/why it would matter in 2wd, but I was never a Ram tech. Just one thing to rule out.
Silly question, but you did verify there was gear oil in the front diff when you installed it, right? I only ask because I've seen guys install diff's only to see them hand grenade on the road test because they forgot to put oil in it.
Sent from my SM-G975U using Tapatalk
