Leveling kit problem
KBExperience
Houston, TX
My buddy (Mac06) and I were working on leveling his truck but we couldn't even get past the first bolt. We took the bolt off of the steering linkage but for the life of me we could not get the linkage out of the UCA. Any ideas? Tried wd40 and a hammer and a pickle fork. No luck.
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Maybe some bolt buster..if not an impact wrench. I was able to do mine with an extension with my ratchet and all the bolts came loose.
KBExperience
KBExperience
Houston, TX
We got the nut off but the steering linkage is like stuck in the UCA
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Im surprised the tie rod separator isnt working..mine work with a screw driver and hammer..maybe let thewd40 soak in a bit or try some pb bolt buster to spray down in there..
TexasRammer
College Station, TX
yours also hasnt been driven for 6 years lol, I helped a buddy with a leveling kit on his 12 and it came out with the tap of a hammer. but like with mine and others that are a lot older they can be a major pain in the ass. pickle fork with air hammer and lots of shaking will do the trick. or you could get some kind of ball joint/tie rod/ pitman arm puller that auto stores rent, it just needs to be the right size. I have an adjustable one that worked wonders on mine, similar to this
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Very true Nick..I should have asked the year truck the OP was working on lol. The trick with the older trucks is to pre soak the nuts, bolts, parts in bolt buster then come back to it. Maybe try an air chisel?
TexasRammer
College Station, TX
haha yeah I guess I just assumed its an 06 because of his name. yeah air chisel is really your best bet if you have one
MAC06
Houston
Thanks guys... Gonna go get me a BFH and some of that bolt buster shizz that apparently everyone but me knew about... hopefully I can get some time again this weekend.
98sporttj
west chester Ohio
2006 QCSB 4X4
4.7L
best thing i can say is get a bfh and hit as hard as u can right on the knuckle where the tie rod goes in... it was jar it loose so u can tap it out... being a tech i hate using a pickle fork cause it destroys the rubber then will cause the joints to fail faster...
redram2007
Colorado Springs (Ft Carson)
I agree^^^. I used a bfh and whacked the knuckle a few times and presto. But the other side was a little tougher. I hit the knuckle a few time and then decided to put the nut back on but only a few threads and tapped on it a few times while hitting the knuckle in between.
omaha123
Nebraska
5.9l CTD
Gotta love a nice bfh!! And some clean and mean rams!
mikep345
