- Mar 14, 2015
- 1,431
- 507
- Location
- NL, Canada
- 2019
- 5.7 Hemi
I have the ReadyLift 2” leveling with upper control arms, part number 66-1921. The UCA will help correct the change in ball joint angle, reducing the stress that might occur if you kept the factory UCA with a lift. The new UCAs are definitely stronger than the stock composite UCAs. I had it aligned after the install.New to the truck world and the forum so please be gentle with me. I have a couple questions about this thread.
1. What is the purpose of leveling the truck?
2. If you level doesn’t that mess up the headlight alignment when towing? Does the alignment get messed up anyways even if not leveled when towing?
Thanks in advance for replies and learning the new guy
To answer your questions:
1. The purpose is mostly to change the look of the truck. Many, myself included, do not like the look of a truck with a rake angle (front end lower than the back.) However, if you tow a trailer much then you need to consider that factory rake results in a level truck when you attach a trailer with much tongue weight.
2. Yes, it will definitely change your headlight angle, and you should adjust them after the install. These new headlights are stupid bright already; tipping them higher into oncoming traffic is ignorant and will get you a lot of high beams flipped at you if uncorrected, this is especially true if you drive country roads where there is not a lot of ambient light that lessens the impact. If you have a level spot about 25 feet from a wall that you can mark, then you can do it yourself by marking the wall where your headlights hit before the install. I don’t have the room for that, so I paid my dealer $80 to adjust my lights after the install. That’s a lot of money for that job, but my headlights are correct now and nobody flips me off anymore.
