levelling kit install issues
Fields_93
Hey folks ! question!
installing my levelling kit got everything pretty close to being done until i went to reconnect my upper ball joint to the spindle and for the life of me couldnt get it far enough down to start the nut.....any suggestions or insight from people who have done this?? thank again!
im new here so i apologize for the new guy question
SilverStreak88
Houston, Texas
5.7 Eco Gasser
What type of kit do you have? I used a 36" pry bar wedged in the lower control arm to lift the assembly into place.
F
Fields_93
I think it's an eBay kit. To be honest. Got it as a gift. 2" spacer in front. 1.5" in the rear
sriley531
Ohio
You should be able to pull the upper arm down by hand, and if needed use a floor jack under the lower arm to raise the assembly up a pinch. I was able to do it all by hand though (this was using bils, not a spacer, but shouldn't matter to that end).
PassivAggressor
Make sure the jack is on the furthest point of the lower control arm. Jack that sucker up until it starts coming off the jack stand. Get your pry bar and get it done.
SwollenMonkey16
yea use the jack and jack it all that way up. should slide all the way in without a problem. I just installed mine this passed weekend
Csanders1992
I just loosened the bolts for the uca lol. Went right in by hand. Then tightened after
F
Fields_93
Thanks a lot for the help! Gonna tackle er again this weekend will let ya know how it goes!
SwollenMonkey16
Let me know how the rear spacers treat you. I still need to install mine. Did you get the spacers that go on top or bottom?
Never Summer
I read a bunch of threads stating leveling kicks kill the ball joints on 13+ trucks. Anyone experience this?
F
Fields_93
I got bottom ones.
I've heard plenty about the ball joint issues but I'm pretty sure anything under 2.5" is safe. Anything bigger you run the chance of it happening
SwollenMonkey16
What size? And the springs just slide right back in? I upgraded my UCAs just so I didn't have to deal with it.
Csanders1992
I got bottom ones.
There have been people that popped them with bils at 2.1. Spacers cause more issues than bilsteins also.
