Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Hi all! I have an '03 2wd, and I have the back lifted 3". I wanted to lift the front to match. Could I do 3" coils with 3" spacers to get 6" total? Thanks!
I think your upper control arm would we sitting on the frame if you did 6" of lift that way rather than getting some lift spindles. Being that its 2wd you can probably pick up spindles fairly cheap for it.
That is def not a good idea to do that you will have to get lift spindles and lift coils then your able to but lift coils and 3inch spacers are not a good idea
