Lift kit VS height adjustable shocks: better for off road?
hodge-xj
5.9 cummins
Looks good man! I was absolutely surprised how much mine settled. About .5-.75" after a bit. Be patient and fine tune it after a little. Angles look good. I ran my truck through a nasty snow storm yesterday, down the highway at 65 in 4wd and it gave me no grief. Our angles are almost identical so I really wouldn't concern yourself much with it.
I do think we need a full truck shot....just saying [emoji41]
As they break in the stiction in the seals will loosen up and it should make the small bump compliance a bit nicer. My 6112s are like butter after a few thousand on them now.
Btw I'm on 285s and sitting at:
39" front
39.75" rear
Edit: found a pic of my angles on my truck just for comparison
Sent from my SM-N920V using Tapatalk
ram1500rsm
Trabuco Canyon, CA
Oh she's ready for the adventure haha..
I think the CV angles are ok, You may have more than 2.5" if your front measures 39.5 with 285's ? she'll drop some anyways from where she's now as you rack some miles and the coil springs settle in full, then you can adjust up if you like.
This is how my CV angles look like today.
47086345761_9de167edcb_h.jpgUntitled by RAM RSM, on Flickr
46172881095_be60430128_h.jpgUntitled by RAM RSM, on Flickr
novelmike
Central California
bruiserRAM
bruiserRAM
Eastern Sierra, CA
The upper control arm still needs to be tightened in this picture, right??
Nope. That's where she sits. It's a tapered pin coming off the delta joint, fully seated. Nut is torqued to 75 ft lbs and the taper pin isn't spinning so it's all snugged up! I wonder if this is why I'm getting extra height above what I was expecting to get...and what icon said I'd get?
Their coilover height (adjustable from 0-2.5" shipper set at about 2.0") is maybe based on either stock UCAs or their uniballs?
ram1500rsm
Trabuco Canyon, CA
You mentioned you adjusted the CO's? i'd assume this is why you're sitting higher at the moment, she'll go down once the coils settle for sure so just give it some time.The BJ's in the UCA won't give you lift increase. Noting wrong with the BJ they just don't have the grease boot because they don't need one like a normal BJ.
bruiserRAM
bruiserRAM
Eastern Sierra, CA
I adjusted them two turn UP the shock body, lowering the front 1/4". Then I rethought it and raised it back up to what they shipped at.
I'm gonna take a long drive this week and remeasure. Gonna start an alignment thread and an Icon install thread soon too...
bruiserRAM
bruiserRAM
Eastern Sierra, CA
Here's what the rake and heights look like after alignment (just posted a thread about alignment, FYI).
Front about 39 - 39 1/8
Rear about 40 1/8 - 40 1/4
tires 285/70/17 (just under 33")
hodge-xj
5.9 cummins
I like it!
ram1500rsm
Trabuco Canyon, CA
They finally arrived last week.
I’m moving into a new house in a couple/few weeks. I think I’m just going to wait till I move in.
I held them up to the Fox 2.0 currently installed, they make them look tiny!
Can wait to see the pics and details, if you can please measure the rear Fox extension and compression to add it to my shocks database.
Enjoy the new house and enjoy the new suspension setup, the difference should be quite noticeable and i mean huge when going from 2.0 to 2.5 CO/shocks.
