jstacey8
What do you guys like better 6 inch with 35's or 6 inch a 1.25 body lift and 37's. I can't seem to make my mind up on what I want so just tell me what you think of both
Some kits will allow 37's with just the 6in. I know for sure that RCX and BDS can support 37in tires with no rubbing off the suspension kit alone.
That completely depends on what wheels you want to put on the truck. A 6" kit alone will never clear 37's on a 12" wide wheel. Most won't even clear them on a 10" wide wheel.
OP, what's your plan wheel wise? Are you looking for a wider stance or something more narrow/tucked?
Op, I've been searching threads about this too. Has anyone out there done a 4" RCX / Superlift and set bilstens at 2.1" and run 37x12.50r20 tires on stock 20x8" wheels w/1.5" spacers?
Minor trimming of the inner fender liner isn't a big deal. I'm not going for the whole 'stuffed" look. But, also not a fan of 10"+ of tire clearance. I'm liking the look of 6-7" of tire clearance.
I know the Mopar underground did a build with 4" lift & 37s, but can't seem to find too much info on what mods they needed to do.
I'm looking at 20x9" wheels with +1 offset (about 5" backspacing) with a 12.5" wide tire.
Anyone have some input on fitting 37x12.50 wildpeaks or nittos with a 4" lift?
my BDS kit clears 37x12.5 on a 20x9 procomp rim with a 1.5 spacer no rubbing. so yeah that's not accurate at all, and your "never" comment is invalid. Right off the BDS site. Also if you need further picture proof I'm willing to supply.
Tire & Wheel Combinations
37" x 13.50" w/17 x 9 and 4-1/2" back spacing
37" x 13.50" w/18 or 20 x 9 and 5" back spacing
2012 Dodge / Ram Ram 1/2 Ton Pickup 1500 6" lift kit 663H | BDS Suspension
Thanks Brandon.
I'm back & forth between 20x9 w/ +1 offset (5.0" bs) or 20x10 w/ -18 offset (4.75" bs). I'm thinking the 4.75" bs will help clear the suspension parts but I'm wondering if it will mean more trimming into the back of the front facia/bumper cover (I have an express). But I'm really leaning towards 37s. Go big or go home right? I loved 37s on 17x9s on my jeep, but want to run 20" wheels because the truck is a little heavier and the center of gravity is higher so I don't want it to feel to squishy in the turns.
Do you have the other guys user name and what forum he's on? I'd love to see his build thread and pick his brain.
