Lifted please read need help deciding
Buckeyedavey2323
If you have a lifted ram can you give me your dimensions from ground to bottom of fender and what lift and tire size your running please trying to decide which way to go
Ratket
Arizona-
Well how high do you want it? Do you want it to fit in your garage? How big is your garage? Do you care about fuel mileage or the cost of tires? How much $$ ya wanna spend? Most are content with a lvl.
B
Buckeyedavey2323
I want it tall but still practical I don’t care if it fits in garage or not I don’t park there and gas mileage don’t care bout that either and tires I get discount on
JB1
Houston, Texas
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
JB is about the most complete build on the forum! He's got it all, or done it all :)
Agreed. I have about same but went with zone to save a few bucks. I will have to get measurements. I purposely left about an inch I believe in rake just to not let the front look higher and also if I tow it's not as obnoxious when the bed sags from the weight
Reactions: JB1
bigred74
Illinois
1999 and 2017
How she looked with a 31ft camper but also had installed a timbren ses system to limit squat. Otherwise would have been real bad lolSnapchat-2142809761.jpg
BOWERSFJ
Uniontown OH
Zone 4"F/3"R with Bils set at 1.4" on 35 x 12.50's 0 offset ... Fits in my 7' garage doora572e24faf0bf6d11ccfcecafce2fc9f.jpg
RLJ10X
Southern Indiana
The cornerstone of any lifted truck is what Size Tires you are going to end up with. You want your truck to end up proportionally correct. JB nailed it, as have a lot of guys here.
Tell these guys what size tire you're going to get, and they'll tell the correct everything else.
JB, there isn't any truck sharper than yours. Bold, yet understated. Love the black grill.
B
Buckeyedavey2323
I want to run 37/13.5/22 tires
bigred74
Illinois
1999 and 2017
you will need 6in lift then
B
Buckeyedavey2323
I heard body lifts were out of the question is that true?
Maligator
Hem 5.7
Zone 6/5 with Bils up front set to 2.8"
Just measured and from the ground to bottom of the fender
Rear 46 3/4" Front 46 1/4"
37x 12.5 tires. 18" -12 offset wheels needed minor trimming on the lower dam. Only rubbed in reverse.80972051d6cf6a8c5f82d1d5fade55be.jpgb8baa8dc92c3ea7f07e79f057c087ab2.jpg
JB1
Houston, Texas
You did a good job on trimming that airdam, looks OEM
JB1
Houston, Texas
Wow....thanks I appreciate that
Maligator
Hem 5.7
Thanks man, if it wasn't for your post on it I'm sure I would have hacked it to ****...haha
