Lifter Failure / Hot Oil / Better Cooling etc.
Update, I went under the truck with intentions of installing the donut gaskets and to my surprise the collector bolts were loose!?
I cranked down on them as tight as I could before with a stubby ratchet so this time I tried tightening them with my 1/2” ratchet long extension and a universal joint.
Going to see if this cures the leaks if so I’ll return the gaskets otherwise that’s the next step. If it does I’ll probably apply locktite to the threads as well.
tightened while cold
Also noticed I have a pinhole leak by the y pipe (my mid pipe is welded directly to the Y cause it used to always leak no matter what)
*update - passenger side leak sound is gone, but driver leak is still there.
Who decided to put an o2 sensor right in the path of the bolt!
Loctite won't do much on the exhaust bolts,as the way you remove loctite is to heat it,so on an exhaust system,every time it gets hot,the loctite is basically null
Black1500Ram
Black1500Ram
Scottsdale, AZ
So after my first trip towing she held up well.
Oil pressure is between 60-65psi up at 3800rpm.
Temps still climbing into the 240°s going up the same grade at 55mph towing the camper, or on flats at 70 also getting to the high 230°s at 2900rpm
With the pressure and temp I’m thinking about adding a thermostatic oil cooler.
Put the OEM muffler back on and boy what a difference while towing… ugh I’m getting old.
Still have an exhaust leak at the collectors. It got worse after the trip.
Those bolts are as tight as I could get them, tighter than I’m comfortable with honestly so those donut gaskets will be going on.
Black1500Ram
Black1500Ram
Scottsdale, AZ
So today was the first day back working on the truck since I towed the camper to the “in-laws” for Thanksgiving.
Put the carven muffler back on and tried to tighten up the collectors since I’ve had an exhaust leak with my AFE shorties ever since I put them on.
I immediately noticed that the bolts were loose again so I got some split lock washers on them to hopefully help with that.
The gaskets that I bought were too small so they’re no help so I still have this annoying exhaust leak that makes my truck sound like a beater.
I guess I’ll try to find bigger gaskets I dunno what else to do.
The bolts are as tight as I can get them with a 3/8” ratchet. I undid the mid pipe and adjusted the y pipe / cats up and down, side to side to get the best line up on the headers that I could see.
Black1500Ram
Black1500Ram
Scottsdale, AZ
Ok I’m still going through it with these afe shorty headers leaking at the collector ball socket connection.
I had bolts initially rattling loose but have since change to 10.9 bolts and that doesn’t seem to be a concern.
However now they’re just not sealing at all.
I’ve bout probably 5 sets of different donut graphite gaskets trying to get something to work. Everything is too thick since it’s not designed to have one there.
I saw on some forums people mentioned copper as a gasket material.
Think some sheets like this would work? Cut a strip same width as the collector ball and bend it around into a gasket.
I don’t want to use cement since it’s semi-perminanet and would have to be ground off the headers.
Also don’t want to buy new mid pipes since they’re like $700+ catted.
Any other thoughts?
Black1500Ram
Black1500Ram
Scottsdale, AZ
Sooo I bought a small sheet of 0.025” copper that I’m just going to cut into strips the make a donut gasket out of.
I’ll hammer the ends a little thinner and then over lap so there’s no gap.
If that doesn’t work it’s getting a healthy application of this. I can’t deal with my truck sounding like an 02 beater work truck anymore.
Black1500Ram
Black1500Ram
Scottsdale, AZ
Sooo I bought a small sheet of 0.25” copper that I’m just going to cut into strips the make a donut gasket out of.
Welp ended up going with the sealer… still ticking / leaking away.
Starting to think the drivers side header has a leak in the welds.
I’m tired of these things; honestly wish I had just kept my oem logs.
Went from Lifter tick to exhaust tick and not my steering column in groaning away making noise on every turn.
Black1500Ram
Black1500Ram
Scottsdale, AZ
So update the afe headers I bought used have a big crack in them on the rear runner. It was not this visable when I first got them.
However my exhaust is welded at the mid pipe collector after the cats since it would always leak there before. I think it’s not perfectly aligned and inducing stress.
I’ve been meaning to cut out the crushed cross over pipe and move it forward so it’s not directly in the way of the teams drain plug and put on a real y and flex pipe… guess I’ll be doing that sooner rather than later.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
You'd think they'd post weld bake to stress relieve weird angle joints.
Then again, that costs mo' money to prevent a failure way off in the future from thermal cycling.
