Very nice , now that's proactive !Well, Ive done a ton of research on here and and taking action now while my engine is young... Just ordered my Redline 5w 30 and royal purple filter.
Thank You for the reply, this pops my bubble somewhat but i will have to settle on a couple of other things,
1. It was a bad batch of lifters, (faulty)
2. I believe as many do that 5w-20 a little thin for the hemis. (Although fine for many other engines)
3. Possible lots of idling.
4. Possible metal temper strength, (lowest on my list of believing)
5. Or just a random hit and miss failure.
I don't believe the MDS has anything to with it as some failures are on engines without it, also some lifters aren't seized on the MDS cylinders.
Whatever the true cause, we may never know but all of us on this forum reporting the issue are doing the absolute best thing in a situation like this, so that we may all try the things we think may help, keep us updated with the results and what i think is the coolest is that there are many different people, trying many different things, maximizing our chances of success. Good job every one.
My experiment is 5.75 or so quarts of 5w 20 PP and 24 oz of pure synthetic lucas oil stabilizer. Has absolutely fixed the lifter tick and makes me feel good, so i will continue this for a while. I may go to 5 quarts of 5w 30 PP and one quart of 5w 20 which will bring it close to 5w 30 but not quite. I know others may disagree with a couple of these methods, but it just another avenue to try that somebody may not have. On second thought im going to do more research on mixing weights.
Don't give up in #4 so quickly. I have thought this was the problem for some time. Has anyone measured push rods from a ticking motor? My Hemi started ticking at 26K. Slight start up tick and light lifter tick until warm then it goes away. My theory is #1, lifter bleed down causing the start up tick, #2, valve train slack that goes away when the metal parts expand from heat. While ticking, the rocker "hammers" the push rod and actually shortens it. Completely uneducated opinion.
Actually a post somewhere, they did measure the pushrods and were different lengths. So i may be in a small state of denial. Im also trying to be optimistic in spite of some damning evidence i suppose.
Are you rebuilding with factory push rods?
No not rebuilding, just doing all the research i can to take the appropriate action now while my engine is young ( 12,000K) to try to avoid the dreaded lifter failure. Or at the least keep it at bay as long as possible.
