Light bar
Iceman6409
Rochester, NY
5.7L 8 cylinder Hemi 2wd
Hello everyone. 2014 Dodge Ram 1500 SLT 5.7 V8 Hemi 2wd. I desperately need a light bar on my tailgate as I cannot see anything at all when reverse lights are on back up. And yes reverse lights work. What light bars would you good people recommend. Price is of concern but not too much overall. I'd say $100 give or take but open to all suggestions. Thank you all in advance.
augiedoggy
western NY
3.0 Ecodiesel
have you considered led reverse light bulbs? they are much brighter...
Iceman6409
Iceman6409
Rochester, NY
Yes I have. They are opne of the options. Exploring a few options like light bars as well
IDSandman
Idaho
I’ve put these in my rear bumper of my last two rigs as well as several buddies. Wired to a switch as well as reverse wire with a relay so as to be able to turn them on without the vehicle in reverse. I’ll be adding them to my new Ram as well.
Nilight 2PCS 42W Flush Mount LED Light Pods Upgraded Spot Flood Combo Driving Light LED Work Light Backup Reverse Light Grill Mount Light for Offroad 4x4 Truck SUV, 2 Years Warranty https://www.amazon.com/dp/B07S7CK2DT/ref=cm_sw_r_cp_api_glt_fabc_HR83ATDVPVHYGD1CXGY6
Badger 13
North Idaho
2013 Dodge Ram 1500
I have the Putco Blade light bar and very happy with it. I also have LED lights mounted below the bumper that are switched independently. I have no problem seeing when I back up.
VA-RAM
STL, MO - Norfolk, VA
2017 Laramie / 2020 Laramie
I have the OPT triple light bar and the turn signal / courtesy lights under the running boards.. The backup light on the tailgate bar is WAY batter than stock...also paired it with OED backup lights...I CAN SEE!!
RacerRon
Missouri
I use this on mine....simple and can see great .
16Ram4x4
Missouri
This is what I did for auxiliary back up lights. Two 20 watts led pods, one Hopkins 5th wheel wiring kit, two muffler clamps, two pieces of angle iron cut to length and holes drilled for mounting of pods and clamps.
These 20 watt pods are really bright and they also make it easy to back up a trailer at night. Total investment money wise about $60.00.
The muffler clamps go around your receiver hitch tube with the open side facing to the front of the truck. The angle iron goes on top of the muffler clamp bracket.
The Hopkins 5th wheel kit plugs into the back of your 7 pin and 4 pin trailer connector, quick and easy wiring. Just cut it off at about four feet. Then just use the backup light and ground wires and cap the rest with shrink tube for future use.
I installed this over two years ago with no issues. Only thing I would possibly do is hang the pods about 2" lower.
turkeybird56
Central Texas
DID U have to get the LP Relay kit? Or did U just wire into 7 pin? Enuf clearance on tailgate opening?
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
This is the same thing I added to my truck and I love it ... definitely something to take a look at for the OP ...
Socalramfan
Huntington Beach
2011 Big Horn
I have Rigid 2" pods under the bumper angled to the sides and work great. Also have a 13" LED bar on the headache rack which lights up the sky behind me when needed.
RacerRon
Missouri
I used a Curt
56584 wire adapter to attach to the trailer harness reverse lamp wire and ground without cutting or tapping factory wires.​
This kept all wires under the truck and can go back to stock by unplugging the adapter.
My truck is a 2021 2500. I am not sure if this is the correct harness for other years but I suspect it is . Tailgate clears everything with no issues. The light is really no thicker than most license plate frames.
turkeybird56
Central Texas
OK, Thanks for your reply.
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
I just bought a pair of 4" square led pods(with amber signal in middle) and mounted them in my rear bumber just above the exhaust holes. I then wired them to the reverse wire in each respective light with a 2 pin waterproof connector. Makes it easier if I have to remove the bumper for any reason. Oh and I didn't do this to the original bumper, that is in the basement wrapped in a bag. I found a good used one and worked with that, then had it painted. No Mickey Mouse here.......
JC4041
Rosamond, CA
It won't be about 60 these days, unless I'm looking at the wrong harness lol.
stomp
Norwich
I put a pair of Quantum from AutoZone on my cargo rack and put a power jack in the cargo light on the back of the cab then tapped the reverse lights so they work in reverse or with the cargo light switch.
Jim welsh
Westminster,MD
I have a led light strip that mounts on the license plate it is very bright easy to install and wire around $100
