Lightning bolt
Tlaramie
I have a 03 ram 5.7 and the Lightning bolt keeps popping up. The truck won't respond to a code reader. Need help
sylver91
Could be a problem with the electrical, battery or charging system. The light also flashes when the truck goes into limp mode.
T
Tlaramie
It is going in to limp mode.
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
also check and clean throttle body, clean the connector that plugs into throttle body
sylver91
If the code reader isn't working then its not able to communicate with the PCM. First I'd check to see if there is power at the diagnostic port or the code reader wont work at all. Secondly if its a communication problem code readers don't do any good at diagnosing and wont pull codes, an actual scan tool would be needed to get further into it.
T
Tlaramie
My truck runs fine for a min then it almost sounds like a switch and starts to loap, dont have any throttle response. It idles up a little and the red lighting bolt is on. I have cleaned and checked all connection nothing chainged. Should I try a new throttle body?
RonJon '06
Southern Minnesota
If the code reader isn't working I would take a look at the circuit board in the fuse box (IPM). A couple members recently had starting/scanning issues and found the boards corroded.
jwheeler
Washington
Scan tool is the same thing as code reader. Just gives more data. The lightning bolt has nothing to do with the charging system. It indicates that there is a problem with the electronic throttle control. Could be throttle body, accelerator pedal position sensor or the wiring and connectors in between.
stevenmicheal
