I wasn't aware of any option as far as traction aids in any other form than stock LSD or maybe Aurburn for the 4th gen RAM 1500? It seems nobody makes chit for this rear diff trucks?, let alone the damn front axel. I'd think the stock LSD is prob cheaper too.
I'll be running an Eaton locker if it was available for my diff but that doesn't seem the case, next will an Eaton Trutrac but i don't know we can run either option in the back. i know 5th gen can be had with a rear locker form the factory, but i'm not aware of anything for the 4th gen 1500 until now, unless something has changed ?
Also i see the poor TC switch always get blamed for everything. Just shut it off when in 4hi (4Lock if you have the 44-45 transfer case) pressing on the switch for about 10-15 sec until you see the TC off message, the TC should go off in 4lo. if you have the 4auto option nothing you do will fix the main problem and how that transfer case operates.
With the 44-45 , your RAM 1500 should be able to do this the whole day without LSD, just like the black Wrangler in this video, it's got a fully open diff but with BLD. We have the same system in the RAM's since the first 4th gen rolled out the factory
I had BLD in my Jeep with no lockers and it worked great, later i added a rear locker and front truetrac cause BLD has it's limitations on rocks, learn how to use your BLD, again this is assuming you have the 44-45 transfer case. For what've seen in videos you don't want that 44-44 if you're offorading in 3 wheels, deep mud/deep snow, sand etc.
i don't know if the BLD system has been revised throughout the years, it works good in my 14 RAM and i have a lot less flex than what my 13 JKU had, still will go 3 or even 2 wheels in a rut and continue to move forward, just feather the gas and keep it steady.. it's still about momentum just like an open diff but you don't have to be aggressive with the gas.
