Limp Mode codes
YellowTruckMan25
Palm Bay Florida
Hemi - 5.7
Truck has been in limp for 3 days now. Just got it scanned getting P0750 and P0882. Wondering if anyone knows what needs to be done so I don’t have to blow money on gettin got diagnosed and can just get it fixed right away.
any
p0700 - p0799 is a transmission fault, but there are other transmission codes
The transmission control relay is used to supply power to the solenoid pack when the transmission is in normal operating mode. When the relay is off, no power is supplied to the solenoid pack and the transmission is in Limp-in mode. The relay output is fed back to the Powertrain Control Module PCM. It is referred to as the Transmission Control Relay Output circuit or switched battery. After a controller reset (ignition key turned to the run position or after cranking engine), the controller energizes the relay. Prior to this the PCM verifies that the contacts are open by checking for no voltage at the switched battery terminals. After the relay is energized, the PCM monitors the terminals to verify that the voltage is greater than 3 volts.
Read more: https://www.autocodes.com/p0882_ram.html
shaunnz
