Long crank won’t start when raining or wet outside
Jsmith29308
Thunder Bay
2001 5.2L magnum
Every time it’s foggy, rainy, snowing or wet outside my truck doesn’t start.
Obviously a Moisture issue somewhere.
I’m thinking cracks in the alternator or bad coils or something. I don’t think it has to do with my air intake system.
Will also shut down if driving through a puddle or following a semi in snowy conditions.
Wondering if anyone else has been down this road?
Blackdodge2010
Alberta Canada
Crack in the firing system components. Check for cracks or damage to coils, plug wires, distributer etc. Make sure all connections are tight, especially with the fuel and firing components.
The water is killing the fire. where I come from we call these "fair weather friends" lol.
Jsmith29308
Jsmith29308
Thunder Bay
Is there only one ignition coil? How many are there?
Distributer looks fairly fresh
Blackdodge2010
Alberta Canada
If you have a distributor then there will be only one ignition coil that runs it. Check the coil, Check the wire from the coil going to the distributor. Check the 8 spark plug wires running from dis to each cylinder. If you can get it in dry conditions and running correctly then a spray bottle of water on mist may help you narrow down which part is giving you the issue. Sometimes it is very hard to see any damage, ends up being a hairline crack on something u cant see.
Helpful tip, WD40 displaces moisture and can help you dry stuff up. Also, in a tight spot, so does hairspray.
dapepper9
Iowa/Nebraska Border
5.9L V8
Wait til it's dark out, start the truck and pop the hood. Take a spray mottle of water and lightly mist it over the coil, the coil to distributor wire, and all your plug wires and until either the symptoms arise or the you see arcing. Easiest way to find it
