Long term damage to engine
Coramie
Hutto, Tx
I bought my ‘18 Ram 1500 CC 6’4” 5.7L Laramie about a month ago. My driveway has a pretty steep incline and I’ve noticed in the mornings when I start it up, it sounds like it’s having to pump fuel into an empty engine. It bogs a little a few times before settling down once the fuel gets to the engine. It doesn’t do this after sitting on a level parking lot all day at work, so I’m pretty sure it’s bc of the gas going to the back of the truck In the driveway. My question is, could this have any long term effects on the engine, fuel pump, or other mechanical parts? Any input is appreciated as I look to have this truck for a long time. It’s my first truck and it’s pretty damn bad-ass!
Thanks,
Cory
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
i bought my ‘18 Ram 1500 CC 6’4” 5.7L Laramie about a month ago. My driveway has a pretty steep incline and I’ve noticed in the mornings when I start it up, it sounds like it’s having to pump fuel into an empty engine. It bogs a little a few times before settling down once the fuel gets to the engine. It doesn’t do this after sitting on a level parking lot all day at work, so I’m pretty sure it’s bc of the gas going to the back of the truck In the driveway. My question is, could this have any long term effects on the engine, fuel pump, or other mechanical parts? Any input is appreciated as I look to have this truck for a long time. It’s my first truck and it’s pretty damn bad-ass!
Thanks,
Cory
Im probably no help but maybe back it in your spot?
Let it idle for a minute before turning off may help.
Coramie
Coramie
Hutto, Tx
Turn the key over one time to the RUN position and let the fuel pump run for a second. When it stops, then turn the key to start. Maybe that might help.
That never even crossed my mind. I’ll try that in the morning and see if it helps.
MADDOG
Living in a Firepit
turn the key to ON but don't start it right away. Let the fuel pump pressurize the fuel system before you start it up.
Coramie
Coramie
Hutto, Tx
I’m going to try that in the morning. Someone else suggested the same thing. Thank you, I appreciate it!
huntergreen
Marine Corps Navy Badge
Does happen regardless of fuel level ?
Do you "tip start" the truck or turn and hold the key when starting?
To "tip start" the truck, just the key all the way to start and let go of the key. When tip starting the truck should delay before cranking(just like when remote starting).
Coramie
Coramie
Hutto, Tx
I’ve never done what you describe as “tip starting”. Even with the key held in the start position there is a short delay before it cranks. This is the first vehicle I’ve owned that does that. Most crank right up once the key hits “start”. My newest vehicle besides this is a ‘14, so maybe it’s become more common than I’m aware of in the last few years.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Just be careful. if the pump goes dry the pump will wear and overheat (even on priming). The fuel in the tank acts as a heat sink and lubrication. So if you have to prime the pump/fuel line everytime you start the truck it could wear the pump prematurely. The fact that you keep it 1/2 or full all the time helps.
Kukailimoku
Honolulu
THIS.
that way instead of the fuel settling overnight away from your block, it'll settle INTO your block. Should vroooom! right up in the morning.
TheM4rxxx
