VernDiesel
Burla I wondered if a ZDDP booster would help make enough of a difference. The one I saw a few years back read to me as light on what you were buying it for and heavy on price when buying an oil plus the additives versus simply buying reasonably priced & easy to get VR1. Any place that sells Valvoline can get it.
Probably the same when comparing to trying to do that versus the overall quality & additives you get with Red Line. I don’t think I would want to run a ZDDP booster on top of Red Line without talking to somebody “in the know” from Red Line first. Some things don’t play nice together.
I may run Red Line on my next diesel. I would look at running it on my existing diesel but I’ve had good results with my current cheap readily available T6 so I hate to switch and lol fix what ain’t broken as they say. I use 3 gallon a month in the truck. Though perhaps I just don’t know what I don’t know yet since the engine has never been torn down & inspected.
BTW I commercially transport TTs & boats for Mfgrs taking them from plants to dealerships with my 14 Ram Ecodiesel. (Mostly in the 5 to 7k weight range). Dependability & fuel economy is greater profit margin. Bought the truck new before falling into the business contracting with Airstream TTs as their plant is close to my home. I know the ED isn’t hailed for reliability but being a diesel once you get the emissions stuff put in the proper receptacle and a good clean non government botched aftermarket tune they become reliable. Well assuming you’re only working your truck with half ton appropriate loads and still do diligent maintenance.
I had 371k when it pushed a head gasket due to low coolant from a leaking EGR cooler. Tune & EGR cooler delete remedied the root problem. It was tore down & inspected but ran two different oils over time and extended oil change intervals twice having oil filter collapse. So some results were skewed. Live and learn I did.
Since then 357k no motor repair or sludge etc issues running only T6. Friend James has 390k on his ED doing the same business also running T6. With both motors looking forward to the eventual tear down.
