Looking for 4th gen build sheets
00R/T
CT
I know there is a lot of confusion out there about the different option codes available on these trucks. Some codes can be added by the dealer to support upgrades, but often times you need to know what the codes are first. There are lists out there, but there's often overlap. I thought it would be nice to put together a database of code combinations specific to these trucks.
So,if you've requested your build sheet, it would be great if you could post it here. Personally I really want to see a '13 Longhorn without tow mirrors. [emoji41]
00R/T
CT
Here's my '13 Express:
Vehicle Description RAM 1500 ST 4X4
Model Year 2013
Body Model DS 6 L 61
Color PRP- Deep Cherry Red Crystal Pearl Coat
In Service Date 08/31/2013
Sales Code Description
V9 Cloth 40/20/40 Bench Seat
X8 Black/Diesel Gray
AGDP RAM 1500 Express
AJH Power and Remote Entry Group
AJY Popular Equipment Group
APAS Monotone Paint
BADP 180 Amp Alternator
BCNS 730 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CBZP Prem Vinyl Door Trim w/Map Pocket
CDRP Front Armrest w/Three Cupholders
CE8S No Lumbar Adjust
CGDS Front Height Adjust Shoulder Belts
CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags
CJ1S Supplemental Frt Seat Side Air Bags
CJ4P Supp Side Curtain Front Air Bags
CKEP Carpet Floor Covering
CLAP Front Floor Mats
CSPS Driver/Passenger Assist Handles
CU3S Behind the Seat Storage / Bin
CV3S Urethane Shift Knob
DBAC All Automatic Transmissions
DG1 6-Spd Automatic 65RFE Transmission
DH9S Elec Shift-on-the-Fly P/Time T/Case
DJGS 215MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRNS 235MM REAR AXLE
DS7S Conventional Differential Frt Axle
DS8S Conventional Differential Rear Axle
EZH 5.7L V8 HEMI MDS VVT Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GT6P Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMP Remote Keyless Entry with All-Secure
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JATS Instrument Cluster w/Display Screen
JBFS Instrument Panel Black Bezel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBP Power Locks
JPYP Pwr Windows, Front 1-Touch Down
JP8P Manual Adjust Seats
LAXS Front Passenger Seat Belt Alert
LAZS Vehicle Information Center
LA6S Incandescent Tail Lamps
LCHS Rear Dome Lamp
LE4P Black Exterior Mirrors
LMES Halogen Quad Headlamps
LMGS Automatic Headlamps
LNJP Fog Lamps
LPES Cargo and CHMSL Lamp
MBPP Body Color Front Fascia
MBQP Body Color Rear Bumper w/Step Pads
MDAS Front License Plate Bracket
MENS Front Wheel Spats
MFTP Body Color Grille
MGAS Ram's Head Badge
MHLS Rear Wheel Well Liners
MNAS Black Door Handles
MPPS Rear Wheel Spats
MS2S Ram 1500 Badge
MUSS 4X4 Badge
MW5P Hemi Badge
MXCS Front Bumper Sight Shields
NAS 50 State Emissions
NERP Dual Rear Exhaust w/Bright Tips
NFWS 26 Gallon Fuel Tank
NHDP Heavy Duty Transmission Oil Cooler
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
PRP Deep Cherry Red Crystal Pearl Coat
QRPS Deep Cherry Red Crystal Pearl Coat
RAAC All Radio Equipped Vehicles
RA1S Radio 3.0
RCGS 6 Speakers
RDDP Fixed Long Mast Antenna
RSDP SiriusXM Satellite Radio
RSUP Audio Jack Input for Mobile Devices
RSXP Remote USB Port
RS6P Media Hub (USB, Aux)
R01P All VP1 Radios
SBAS Power Rack and Pinion Steering
SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHFS Rear Stabilizer Bar
SUAS Tilt Steering Column
TBMS Tire Carrier Winch
TBSP Full Size Temporary Use Spare Tire
TUBP P275/60R20 OWL All Season Tires
TZAP Goodyear Brand Tires
WF1S 17" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
WP2 20X9.0 Aluminum Chrome Clad Wheels
XA8S Non Adjustable Pedals
XBNP Tip Start
XBSS Pickup Box
XCMP Vendor Painted Cargo Box
XFHS Class IV Receiver Hitch
XFKS 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XF9 Add Class IV Receiver Hitch
XGMP Tire Pressure Monitoring Display
XJCP Locking Lug Nuts
XJJS Locking Tailgate
XJ8S Body Color Fuel Filler Door
XKDS 'Why Buy' Label
XLNS English/USA Language
XM9P Delete Spray in Bedliner
XZNP Raised Ride Height
X8ZS Seat Parts Module
X81S Instrument Panel Parts Module
X82S Door Parts Module
X83S Front End Parts Module
X88S Tire & Wheel Parts Module
X9BP 1-Yr. SiriusXM Radio Service
YAAS Build To U.S. Mkt. Specifications
00R/T
CT
sbarron
Wasilla, Alaska
yeah, the real problem is known the complete combination for the correct option package, still, I don't think the build sheets make any more sense unless you actually understand how the option packages fit together on the individual trucks.
stevenmicheal
