Still have stock light on my 2016 1500, the fog lights wobble very noticeably on bumpy roads. Ive looked at the housing and its just plastic wear, poor specs etc... Has anyone else encountered this and did you find a fix?
Permanent fix for your loose fog lamps. If you buy new, it will just happen again. Purchase four 1/2"×5/8" rubber grommets. Drill current 1/2" holes in fog light housing mounting bracket into 5/8" holes. Insert grommets into holes and reinstall fog light housing starting with the bracket side with two holes. The grommets will act as a dampener t ok breduce vibration while also protecting the plastic from additional wear. Takes less than an hour and while your in there anyway replace the stock 9006 with a set of 6000k led 9006 bulbs.
Had the same problem. I got under the front bumper and saw that under each fog there is plastic wing that you can tighten. I just cranked it until there wasn't any give. It raised the spot, so it seems to me like the wing is so that you can aim the light. It is a short term fix, but I rarely use the fogs anyways. Hope this helps
