93W350
- Dec 6, 2017
- 7
- 0
- 1993
- 5.9 Turbo
Hey all. I posted my issue about my lose steering back in December but haven't been around to follow up as I do some contract work that takes me away for some time. Anyway my 93 W350 has extremely lose steering that no one can figure out. The latest scoop I got was regarding the Spool Valve inside the steering pump. Apparently the spring is too soft and continuously allows fluid to pump through. I'm told there was once a kit to replace the spring to fix the problem but the local dealer knows nothing about it. Anyone ever hear of this issue and know of a kit or other means to correct the problem?
While away I left my rig with a friend that manages a tire and suspension shop and he tried adding shims which only made the issue worse. Would the tire size or tread pattern cause my lose steering problems? They're stock size but a little more aggressive than highway tires.
I've replaced the gear box and pump so far. I also have the problem of no return to center at all.
