Johnbrown8907
I have a 2005 hemi 4x4 I’m having an issue with it losing oil and coolant but there is no leaks and no weird smelling or looking exhaust. Had anybody else had this issue? Thanks in advance.
Heater cores dont leak oil heater cores leak coolant if your floor is dry then it wont be it. Also you should pick up a block tester they are cheap you will be able to tell if there is exhaust gasses in coolant/bad heas gasket.I'd like to see compression test numbers. Heater cores don't leak oil but bad head gaskets can.
Correct oil looks fine mileage is 194k. It would burn almost all the oil in 3-5k if I didn’t keep an eye on it. And the coolant I typed off just a few days ago and when I got the oil changed this morning they said it was almost empty. Passenger for board is dry.
I’ve considered a swap, but I was considering a newer 6.4 hemi or a 5.9 Cummins but I think of I did either of those I would need to do whole drive train. Any thoughts on either of these?Obviously, you do not keep as close an eye on the vehicle fluids as that vehicle requires. You know you got to watch it, yet it was almost empty at last oil change.
If there is no leaking, which you would notice on the ground that much oil and anti-freeze lost, then it is burnging both of those fluids through the Compression chamber.
Being it is both anti-freeze and oil, my first suggestion would be Heads, head gasket or valves are leaking or a combination of all three.
The top end of the motor can be repaired but, with those miles, all that is going to do is blow out the low end.
At this point, either do a complete rebuild, get a long block from somewhere, or pick up a junk yard engine and slap it in there.
Whichever way you go, every fill up, check your fluids !
Good Luck and no matter which waya you go, there are plenty of folks on this forum who have done the swame are more than willing to answer any questions.
FYI to put a 5.9 CTD in a 1500 would take a lot of work, mods along with $$$ to beef up the front end to be able to hold the weight of that engine then the rest of the frame would also need to be beefed up....I’ve considered a swap, but I was considering a newer 6.4 hemi or a 5.9 Cummins but I think of I did either of those I would need to do whole drive train. Any thoughts on either of these?
I think you need a new truck.I’ve considered a swap, but I was considering a newer 6.4 hemi or a 5.9 Cummins but I think of I did either of those I would need to do whole drive train. Any thoughts on either of these?
Going to get a new daily driver but this will be a project truckI think you need a new truck.
