Well She is done, I pick it up tonight.
Run down of what was done due to loss of tire.
New rotor
New studs
New rim
New tire
New TPMS]
Tire mount and balance
New center cap (hub cap)
Axle verified for trueness (not bent)
All tires verified for torque.
Front tire studs visually inspected (determined good this is on the bill)
Optional maintenance done
Replaced studs on other rear tire (made me feel better)
Brake caliper slide pins lubricated (all four, they were due)
Oil change (was originally going in for this the next day but arrived one day early due to the incident) LOL!
Shift pin recall
Water pump recall
Total cost out the door just short of $3000 (taxes in)
Still to be done.
Plastic trim over fender opening to be replaced and painted ($500)
Trailer fender flair and skirting to be replaced ($1200)
Since we decided not to go through insurance as this would have been counted as an at fault accident which would effect my insurance rates about the same as the total cost we decided not to take the hit on my driving record. The things still to be done are simply cosmetic, so we decided to spread the cost out. Plan to pay off the mechanical repair to the truck, then repair the RV right before we put it away for the season, once that's paid for we will repair the fender trim and paint during the winter while the truck is not used.
This could have been much worse. We are just glad the tire didn't hit anything else and no one was hurt. I guess maybe I'll start verifying my lug nut torque every time I move the truck, seems like the only option to minimize the risk of this happening again. If it wasn't the torque don't know what else I could do.
On a side note, I kept the broken studs, one of the lug nut I found on the road with the other side of the stud still in it and the studs from the other rear side that I changed on spec. I work in the air industry and have the ability to have the broken and good studs inspected by the same people that do aircraft crash investigations. We'll see if there are any indications that something is wrong with the studs or not. Should be interesting to see the results.
