bwhay
- Dec 9, 2013
- 42
- 16
- Location
- Stony Plain Alberta
- 2014
- 5.7 Hemi
I think you have that backwards. I have always been told diesels were ment to idle for longer periods of time and I don't think its as bad to idle a gas engine as it used to be with carb and TBI as fuel is managed a lot better and better additive packages in oils.
Are you able to buy a portable heater that you can plug into a socket near the outside of the truck? I'd assume it would be able to keep you at a better temperature then outside without idling haha.
I am curious why your degrees in Celsius and Ferenhite are the same when you switch back and forth.
