Etroze86
- Nov 4, 2012
- 4,807
- 860
- Location
- Grand Forks ND
- 2011
- 5.7 Hemi
wow didn't know that
I'm not sure if one can make a connection between lifter failure and idle time... Because lifters failure could also be just random poor quality control, and we don't have good data to analyze to connect lifter failures with idling.
Anyway, I'm of old school mindset that truck needs to be warmed up before driving it. I have remote start and warm it up about 5 minutes each morning whether it's hot or cold in CA. I don't idle at all when it's warmer up.
It did have lifter failure around 60k, 90k now
and mds not turn off from a tuner ! glad did mine 10 years ago ! people say I was crazy ! was the worst idea dodge ever had ? I just talk to a guy lifters burn up went bad 5,000 his own money to fix at 115,000 miles not good !Think it's time to bring this thread back.
I was reading an article on the Allpar web site that idling, due to low oil pressure is a major reason that lifters and cams fail in the Hemi's.
Thoughts and experiences?
yes found mine at 26 idle not good so leave on defrost all the time so I get 32 psi another bad idea set at 500 rpm always trucks were 650 rpm ( my chevy trucks ) my camry ! they say its find no way bet lifters running dry didn't find warm up did much so just put on defrost low and turn heat way down ok ! works on cool in summer on defrost too crazy but better save engine I feel ! old school mechanic 70 s ok !I do the same for warming up...as a general rule I won't drive the truck unless the coolant temp has reached 104. However, when the vehicle is cold it is at high idle and the oil pressure is rather high, around 50 psi vs when it is warm at idle 25 psi.
your so right turn off mds 10 years a go I new this was going to happen guys played with 4 on 4 off years ago 70 s blew up engines ! so easy just turn on defrost so get maybe 30 at lest at idle also idle set to low 500 not 650 like a lot of trucks and cars ok ! even fan on 1 well work in summer too use the temp to cold and alls cool ! I have not found my deablo to rase it sucks but so this is all that works bad in idle and drive think of oil slowly getting to lifters 105 out in stuck california high way a hour owwww not good I bet ? use amsoil helps a little at lest ! seen 27 psi the change defrost on 31 ya no cold air to me sucks and I love my truck too over my tahoe i had ! so hopes its not to late to save some trucks wish i had my 383 in my truck was a great engine !Think it's time to bring this thread back.
