Nathaniel Mathis
I get a loud continuous hum from my woofer after installing aftermarket amp. Anyone else have this issue? I have a 2019 Bighorn.
Sounds like a ground or RCA
So after disconnecting the microphones everything starting working smoothly. It was the mics under the drivers seat. I still have use of them but was told it was the highway mics that had to be disconnected.
PS this is caused by the ANC system, not grounding issues, et al. Disconnecting the mics will resolve it. But are there actually mics under the seat or are you saying you disconnected the wires on the silver box there (as noted in other places on this forum)? If the latter, which wires did you disconnect? I've seen discussion of the four mics and their associated wire coloring but not which mic number is where.
The mics are in the headliner but there is a box under the seat that had to be disconnected.PS this is caused by the ANC system, not grounding issues, et al. Disconnecting the mics will resolve it. But are there actually mics under the seat or are you saying you disconnected the wires on the silver box there (as noted in other places on this forum)? If the latter, which wires did you disconnect? I've seen discussion of the four mics and their associated wire coloring but not which mic number is where.
Thanks for your input. I will post up what happened and the fix in a couple hours.
