troy rector
dodge ram 4.7 low oil pressure issue, i recently purchased an 04 ram with 167000 miles the person that sold me truck said he was having alot of engine management issues code for int. cam sensor, and i did notice engine noisey but not knocking, so i bought it, did body work and paint fixed som other minor issues till cam sensor code cam up, would run poorly int. and then ok but cel light would stay on most of the time, replaced with factory parts cam and crank sensor light came back on, at this point suspecting noise maybe related to loose timing chain, all of a sudden low oil pressure issue developed chnged sensor same deal did oil chnge thicker oil, same deal, pulled off pan, found fragments of guide in pan(timing chain guide) upon further inspection found fragments clogged in pickup tube screen<long story longer i am repl rod bearings, timing chains and tens and guides, oil pump and lifters, need torque specs. or directions to get specs
