Yardbird
You could do what I do in cold weather.....Hold the throttle pedal to the floor, then turn to start, or push the start button. With tip start the engine will continue to turn over until you hit the button or turn off the key, but the engine will not start with the pedal to the floor.
After 5-10 seconds stop the starter, as oil should be pumping through the system by now. Then start normally.
