Lance1985
- Oct 16, 2022
- 19
- 12
- Location
- Surprise, AZ
- 2019
- 5.7 Liter V8 HEMI MDS VVT eTorque
Given: 2019 1500 2WD stock 50K miles
Grinding sound at steering wheel when moving very slowly and turning the wheel +/- 10 degrees in either direction both moving forward or backward. Does not occur at normal speeds. Dealer found steering rack mounting bolts loose and when tightened noise went away at least at the shop but not afterward. AI suggests it is a known issue on some RAM trucks and may not be resolved by simply tightening bolts and lists a multitude of possible causes. Surely someone on the site has experienced and solved this issue. I an open your experience.
