dick strough
On my 01 1500 4wd the grease zirks on the bottom ball joints are straight up and under the u-joint. There is about a half inch clearance . I tried the slotted stem that pushes on the zirk from the side, no luck. Has anyone replaced the zirk with a ninety degree zirk with any success? I got mine soaking in PB blaster, didn't know about applying heat. Thanks, ****
