Quicksilver337
- May 27, 2012
- 690
- 138
- Location
- South FL
- 2016 Ram R/T
- Hemi 5.7
Why do you keep offering for sale all the parts I need to lower my truck correctly? My wife is tired of hearing me ask for these parts.
What did you end up using to lower your truck?
i felt the same way about the inez brackets they seem a bit on the flimsy side.I just kept the Inez rear brackets, too lazy to swap them out for these which are better quality. They seem heavy duty compared to the Inez
What you do paint them? Looking good, would look better under my truck.
I didn't paint them left them in primer to paint them any color
I agree they would look great under your truck
I know! I need this kit really bad just don't think you would like the offer I could make right now.
you wouldn't know unless you try
So I have the factory air ride, this really won't do anything for me, right? I have the modified links that trick the air ride to allow the rear to drop about 1.5"-2" lower than stock to level out the truck, and when its in the lowest position I get a lot of wheel hop. Its usually at slow speed in parking lots not on the road, but if there is a way to improve it, I would be interested.
Thanks!
Rear Correction Kit for your 09-18 Dodge RAM 1500! This kit fixes your wheel center with a better rear link geometry, using your factory links.! So if your at a 4" drop or more, then you'll notice that your rear wheels are no longer sitting at center of wheel wells... On top of this you have horrible wheel hop due to bar geometry, and high speed wobble; which this kit fixes! THIS KIT WILL ALSO ALLOW FOR UP TO A 7" DROP..! If going lower then you must also purchase pan hard bar drop mount.
