Milt IV
- Aug 18, 2015
- 321
- 110
- Location
- TX M'F'er
- 2015 Sport
- 5.7 Hemi
First things first, 2015 sport 1500 crew cab 4x4. I want the appearance of a 2/4 drop on a 2wd and nothing less. I'm assuming a 2/4 on a 4x4 is not the same as a 2/4 on a 2wd since the 4x4 sits higher from the factory, correct? I plan to run the SRT 22" reps with 305/45/22 as well.
So after reading through a bajillion threads the past two days I have read so much different info I seem to be more confused than when I started out.
The only kit I see listed that is 4x4 specific is the GF 9984 and it is advertised as a 2/3, although it looks like some people were netting more than 3" in the rear. I have also read that some people run the McGuaghrys spindles up front for a 2wd on their 4x4 even though they are not listed as compatible.
Some people say go with a spring drop all around, some say use spindles up front. Some people say cut your factory springs. some people say get a drop spring for the rear and cut it for more drop. So what does everybody recommend for the 4x4 to get it where it looks like a 2wd with a 2/4 drop?
I am also reading about helwig, spohn, and even f150 end links.
So what all do I need, right up front, so I can do everything all at once, the drop, relocate the rear axle, make sure the sway bars are in the right place etc.???
Sorry for the long post and asking all the same questions that have inevitably been asked before in other threads. I'm just trying to get all the answers in one place from the guys who have the experience and can point me in the right direction to do everything right the first time. Thanks
