Lowered my truck 2 years ago and just remembered
Jefferd
Savannah
It was a 3-5 lowering kit and the front shocks didnt seem long enough .. so i put the factory shocks back on... question is was maybe they will fit now the spring has settled? Just wondering im about to install end links any way
aRBee4863
Boise, ID
Which kit did you use? 4x4 or 2wd? I remember lowering with the Bell-Tech kit and I think you're right, but both the spring and the shock is shorter than factory so you have to start putting weight on that side before the distance is short enough to get the shock on, iirc.
Jefferd
Jefferd
Savannah
Thanks jus saw this its been 2 years maybe they will bolt up now
