Finally replaced the oil at 100,000 miles. Did it immediately after arriving at home to see it there was any foam in the hot oil. There was no foam whatsoever. The stabilizer did assist with cold starts since it's getting into the winter months in PA. It also extended the life of the oil. Normally the oil pressure gauge starts to decrease on startup position around 7000 miles but now it stays constant the full 10000.
² Engine Oil Pressure Message - The instrument
cluster circuitry restricts the oil pressure gauge
needle operation in order to provide readings that
are consistent with customer expectations. Each time
the cluster receives a message from the PCM or ECM
indicating the engine oil pressure is above about 41
kPa (6 psi) the cluster holds the gauge needle at a
point near the middle increment within the normal
range on the gauge scale.
² Engine Oil Pressure Low Message - Each
time the cluster receives a message from the PCM or
8J - 32 INSTRUMENT CLUSTER DR
ODOMETER (Continued)
ECM indicating the engine oil pressure is below
about 41 kPa (6 psi), the gauge needle is moved to
the graduation at the far left end of the gauge scale,
the check gauges indicator is illuminated, and a single
chime tone is generated. The gauge needle
remains at the left end of the gauge scale and the
check gauges indicator remains illuminated until the
indicating that the engine oil pressure is above about
41 kPa (6 psi), or until the ignition switch is turned
to the Off position, whichever occurs first. The cluster
will only turn the check gauges indicator on in
response to an engine oil pressure low message if the
engine speed message is greater than zero.
no do rp i do amsoil no problem but only 59600 miles on mine !Should I do penzoil platinum 5w20 ?
Sir, i'm writing this with best of humor in mind i promise. But if he doesn't have it figured out by now, he probably wont. That post is 5 1/2 years old.
But definitely thank you for trying to help.
Why did i notice this? Because yes i have done it a few times myself.
Iv done it too.
No harm no foul right...
But sometimes I do it intentionally to bring up an old but good topic.
Sent while firmly grasping my redline lubed RAM [emoji231]
so now 2020 ya a ticking going on one exhaust replace this year and fuel injector went bad ! stealer says other is ok owwww a lifter ? TIC TIC TIC BOOB ! luckis has help it get less noisy so well try redline oil soon on mine ! 61.000 on her sad all going on now stalls at stop sign not sure why yet ! low miles and this going on so sucks !no do rp i do amsoil no problem but only 59600 miles on mine !
