Lumbar support
Puffin
W. Pa.
6.7L Cummins Diesel
My 2014 LonghornLaramie lumbar support button when pushed produces no movement and no noise that would indicate pump for seat activates. The rest of the seat electronic controls work ok. There is no fuse for the lumbar support. ANY SUGGESTIONS on what to do to fix it.
thanks
18harvest
huntsville
It's not a pump it's a plastic piece that moves up and down and gathers up.all seat adjustments are on the same fuse.probably a motor or could be wires wore
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
thanks
Mine occasionally does this. Try giving the switch a good wack.
