Help Support Ram Forum by donating:
MAF Sensor?
Discussion in 'Engine & Performance' started by Jock Hiltz, May 2, 2019.
Sponsored By: Moe's Performance
  1. Jock Hiltz
    Jock Hiltz Junior Member
    36
    14
    8
    Oct 23, 2018
    Halifax
    Ram Year:
    1989
    Engine:
    318
    Does an 1989 Power Ram have a MAF sensor or equivalent sensor ?
  2. tidefan1967
    tidefan1967 Senior Member Supporting Member
    51
    1,567
    2,124
    Feb 3, 2018
    Summerville, South Carolina
    Ram Year:
    Engine:
    No mass airflow sensors back then on hardly anything. You got a pre-Magnum 318 with a throttle body so its basically an electronic carburetor. You getting any codes on that?
  3. crazzywolfie
    crazzywolfie Senior Member
    15,264
    2,571
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    it is more than a electronic carburetor by 89. you are probably thinking map sensor.
  4. Jock Hiltz
    36
    14
    8
    Oct 23, 2018
    Halifax
    Ram Year:
    1989
    Engine:
    318
    no check engine light but I haven't check the codes yet... just getting what feels like a miss fire when I accelerate...
  5. Jock Hiltz
    36
    14
    8
    Oct 23, 2018
    Halifax
    Ram Year:
    1989
    Engine:
    318
    Yeah, the truck is new to me, and im getting a miss fire when I accelerate... trying to poke around at what could be the issue
  6. pacofortacos
    pacofortacos Senior Member
    607
    623
    Apr 18, 2017
    Ram Year:
    Engine:
    Usually not a bad map doing that.
    Look at spark first.
    Couldn't hurt to run some Techron fuel injection cleaner through it either.
    Jock Hiltz likes this.
  7. crazzywolfie
    15,264
    2,571
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
  8. pacofortacos
    607
    623
    Apr 18, 2017
    Ram Year:
    Engine:
    If you haven't done a tune up yet.
    Personally, I only ever used and prefer the factory Mopar cap and rotor - the clearances are always correct and the vent is correct. Some people like the brass inserts but they don't work well in the humid area where I live - I can't tell you how many cars I have fixed by just putting the factory cap and rotor back on back when I was a Chry. tech.
    Spark plug wires - the best bang for the buck are the Summit 8 mm wires, high quality, durable, great price.
    Plugs - I prefer the factory spec Champions, maybe NGK's, not an autolite fan.
    I also liked running either a higher output coil or a msd 6A with a stock or aftermarket coil.
    Cap and plugs seemed to last longer with the MSD/stock coil combo.
  9. Jock Hiltz
    36
    14
    8
    Oct 23, 2018
    Halifax
    Ram Year:
    1989
    Engine:
    318
    thanks!
  10. pacofortacos
    607
    623
    Apr 18, 2017
    Ram Year:
    Engine:
Share This Page
